is there any site that has samples or pics of shows that are capped from tv with a dvd recorder?
Well, there probably are, but none come to mind offhand. Why would you want them? If you are trying to find what quality a settop recorder would have, a lot would depend on the source. If you want to compare different settop boxes, I would look for reviews. If you have a partictular machine in mind, usually a Google search will give you a link to a review.
Originally Posted by lansky
All I can tell you is that the picture quality from my Panasonic standalones -- the DMR-E50 and the DMR-E80H -- are essentially "as good or better than the source" when recorded at the best picture quality setting (XP). As many of us have mentioned here, it seems that the circuitry within the Panasonic units actually seems to "clean up" the video from videotapes a little bit, making truly excellent results. And, the picture quality from my "direct from cable" recordings at XP quality have been superb -- easily just as good as the original broadcast.
Bottom line, I just don't think you can find "better" quality, unless you're perhaps looking at some of the lower quality settings, and would like to compare and contrast those. I'd just recommend going to a "return-friendly" store and buying a machine -- if you don't like the quality, just take it back! Beats me how you could do any better, though!
thoots
LFE audio samples, are there any samples to download and try
By wetduck in forum Newbie / General discussionsReplies: 0Last Post: 14th Mar 2011, 09:17 -
Motion² - first samples!
By nitro1973 in forum Software PlayingReplies: 1Last Post: 25th Apr 2010, 16:00 -
Make samples ?
By yabbah in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2009, 06:41 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
DVD samples
By michcio in forum Video ConversionReplies: 14Last Post: 10th Jul 2008, 19:53
