  1. what is a GOOD card to capture shit so its digital. i dont know how to word it but the shti i want to capture is digital :P . i dont want to buy like a 1000$ card, something that is good and afordable
    USA
    How about the Canopus ADVC-100? Check the capture card listing to the left of this site for reviews. It's a little pricey at $250US, but works great. For the record, though, all capture cards are digital, that's what computers work with. It depends on what you have to capture, how much of it, what you want to spend, how much work you want to do to get your end product, be it DVD, SVCD, VCD or whatever. If you want to spend less than $100US there are many, many capture cards that work. Take a little time to study the forum here and the capture card listing to the left.
  3. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    Why dont you try to read some of that shit we have to the left. And then ask a question with a little more detail, so that we can understand the shit you are trying to ask advice on.
    SLICK RICK
    Nobody likes a bunch of yackity-yack.
    Originally Posted by lansky
    to capture shit
    I use toilet paper on a daily basis.
    But seriously, also look at an ATI All In Wonder card... maybe... it still depends on what you want to do, which you haven't outright said.
  5. Are there any capture card that has DVI input? I just noticed my satellite receiver has a DVI out. I was wondering if I can capture with it?
  6. will a dvd recorder work?
  7. Member vhelp's Avatar
    Mar 2001
    New York
    I think the sht he's talking about is the GIGO - - really :P
    Yeah, "Garbage in, Garbage out" is what he's refering to.
    -vhelp
