Simply put, is this possible? Any help would be greatly appreciated. Thanks.
-David-
Results 1 to 15 of 15
You have to have a star chip or a mod chip installed, I followed a link, and there was a speical template there that writes an mpg that the PS2 can play,
Sorry can not remember the link, but it is out there,
I did not try it because, the format would not work on standalone DVD players
Not much help I know, but look around, instructions are there somewhere
Paul -
As yet, there is no way to play standard VCDs on a PS2.
Regards.
Michael Tam
w: Morsels of Evidence -
How retarded. It would've been so easy to make that thing play VCDs and SVCDs. Their loss I guess.
yah right. for less than half of the money of a ps2 you coulda gotten a much better dvd player. the thing is so pathetic it doesnt even have dolby, theres no way it would have VCD
The PS2 as a game system is good, but they tried to put too much into it, not only were the components (like the DVD player) low quality (like Avatar pointed out no DD), but it made the price go up much higher than needed. I think that they should have made a game console-only system for those people that already had DVD players and everything else.
what are you guys talking about.my ps2,and all ps2's have dolby digital and dts.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
yep..they all have a dts/dd digital output.....they dont play vcd but play audio cd-r ok.
On 2001-07-10 21:21:10, gambit32 wrote:
Try this link:
http://63.217.26.28/ps2/ps2_utils_graphics.shtml
That link is for playing ps2 on a cpu> I think the dude wanted to play vcd on his ps2. There are 2 ps2 vcd players that I know of. Look on your favorite PS2 FTp.
Here's some of the NFo
PS2 VCD player
Supplier ..... : JADEPSX TEAM
Release Date .. : 29/03/2001
Packager ..... : JADEPSX TEAM
Release Type .. : PS2
Cracker ...... :JADEPSX TEAM
Format ........ : special
Disk(s) ...... : xx/1
Platform ......: PS2
RELEASE : WeWt
Here it is after many long hours of work, a ps2 VCD player. When you
get bored of leeching ps2 games, get yourself some VCDs, SVCDs or DVDrips and
use our tool to make them PS2 compatible. Now you can play both DVDs and
pirated movies on your PS2 (the way WE like it baby) !! Expect more l33t
releases from JADE int he near future. Happy wanking to your PS2. Good Luck,
El
If they build it, we will rip it down, then copy it, and give copies to all our friends...
Piracy is a state of mind - not reality !! -
Have you actually tried it?
This does not let your PS2 play ordinary VCDs... but rather convert your VCDs into a PS2 compatible format.
Regards.
Michael Tam
I was going to start a new thread but its sorta related to this one,
I read somewhere of a PS2 utils disc that had a DIVX player on it??? Is this true and can anyone shed some light on it?
Cheers
G
No its not true. there is currently no way to play a vcd or divx on the PS2.
Regards.
Exactally...No one said it was going to be easy.. To use the vcd player follow these simple steps.
1.Unzip the PS2VCD.zip to your C:\
2.This should make a directory C:\PS2VCD
3.Now encode your pss. Follow the instructions in the included document.
4.Take your encoded pss and name it MOVIE0.PSS
5.Place the MOVIE0.PSS file into the \MV directory replacing the existing file
6.If you wish to include a title screen for your movie make a picture of the dimensions 640x448
Use the included tool to change in into a TIM file take and name this file MOVIE0.TIM
Replace the TIM file in the \DATA dir with your TIM
7.Now Unzip and open up the enclosed the program CD/Dvd Generator
8.Select File\Open then locate the VCD.CCZ in the C:\PS2VCD\
9.Open this up and then select Export iml file
10.Now export this iml file to the C:\PS2VCD directory
11.And finally run the Go.bat file
12.This will build the image needed
13.Burn this image in CDRWIN using Mode2 CDROM-XA Options
14.Swap using your favorite trick and enjoy.
An audio convertor
and TMPGenc is supplied to help in the pss conversion process
Have fun!
El
There is also a VCD player-not the gypplayer- for the dreamcast but it sucks.
Dont like the PS2 movieplayer?
Try PSS PLEX.....
http://63.217.26.28/console/cgi-bin/dlps2.cgi?pssplex-setupfull!exe
PSS Plex is a collection of tools which are able to de-multiplex (split) a PSS movie file into it's component MPEG2 Video and WAV Audio streams, and the other way around multiplex (join) a MPEG2 Video and WAV Audio streams into a PSS movie file!
It also includes a tutorial on how to rip 5 games (Zone of the Enders, Extermination, Warriors of Might & Magic, Army Men Sarge's Heroes and XWinter games) while keeping the movies!
But you still have to do some monkeying around .
Have Fun,
El
_________________
<font size=-1>[ This Message was edited by: El_Smeagablo on 2001-07-12 18:01:17 ]</font>
Using my UK PS2 in the US
By ob7777777 in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2010, 22:36 -
Capturing PS2 Footage
By -ODeN- in forum Capturing and VCRReplies: 3Last Post: 6th Jan 2009, 15:21 -
PS2 Mod Chipping...
By SE14man in forum Newbie / General discussionsReplies: 10Last Post: 20th Jan 2008, 15:38 -
Backing up my PS2 games....
By SE14man in forum ComputerReplies: 23Last Post: 16th Jan 2008, 11:12 -
Ps2 to Laptop
By sk8erkho in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2007, 11:31
