Results 1 to 10 of 10
  1. I have obtained a live Radiohead gig which has two folders-VIDEO_RM and VIDEO_TS. I presume that these are DVD+R folders. However, I have a DVD-R writer so the question is-can I convert these folders so that they are compatible with DVD-R ie VIDEO_TS and AUDIO_TS?
    Ade
  2. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    Why do you presume that they are DVD+R folders? There is no such thing.
    Have you already tried burning them to DVD-R?
    SLICK RICK
    Nobody likes a bunch of yackity-yack.
  3. When I try to burn the video_ts folder in Nero as normal I get a "DVD Video files realloation failed" message. If I try and include the files inside the Video_rm folder I am told that they can not reside inside the Video_ts folder. I can play the video via the PC OK.
  4. ok... read this post
    https://www.videohelp.com/forum/viewtopic.php?t=189999&highlight=
    the dvd created has a VIDEO_RM folder.
    Philips DVD Recorded DVD's create the same Folder.
    Check it out.
  5. this is what you just need
    1. Rip the dvd in in IFO mode. Rip it to your hard disk, do each recording to a separate folder
    2. open IFOEdit, open the IFO in it from one of your folders, Go to VOB Extra's, Create New IFO's.
    3. when the window comes up, make sure the destination directory is in that folder. click ok. it will create new IFO's
    4.Open dvd shrink.
    5.Open files ----> choose the IFO in the folder you have just created with the new IFO's
  6. The problem is that I don't have a dvd to rip only two folders on my HD-Video_ts and Video_rm.
  7. sorry... don't know then... try and get your hands on the dvd
  8. Member Ironballs's Avatar
    Feb 2003
    Under me bird
    Adepizza,
    You may have done this, but when using Nero, use the DVD wizard. When the VIDEO_TS and AUDIO_TS template appears drag the files from your VIDEO_TS folder on your PC's hard disc to the Nero writing side.
    I'm not sure what the video_rm folder is, but you should be able to copy it over, make sure its at the root of the DVD structure.
    Burn away.
    Hope it helps
    Ironballs
  9. Member SLICK RICK's Avatar
    Mar 2003
    Have you tried to open the video_rm folder, if so, what is contained in the folder?
    SLICK RICK
  10. In the Video_rm folder are the following files-
    VIDEO_MN.DAT 2KB
    VIDEO_MN.IFO 2KB
    VIDEO_RM.BUP 32KB
    VIDEO_RM.DAT 1024KB
    VIDEO_RM.IFO 32KB
    Hope this helps
