Hello all,
I have a particular MPEG-2 that i'm having problems creating any chapters for. I'm using Sizzle 0.5 (v0.5.0b1).
Whenever i try to add chapters to a specific mpeg after i save the image and try to play it in apple dvd player i am not able to navigate through any of the chapters. i've tried to recalculate timecode but it did not work. anyone know of any other tricks?
thanks
I'm a little lost...Why aren't you using the Chapters feature per title in Sizzle? With your title selected, go to Chapters, create new chapter,
and highlight the default time it gives you, change it to the specific time
you want, then once done for each chapter you want to create per title,
then save image later for burning? -
The trick is to do it before you save the disk image! Use the chapters tab and set your chapter marks and what not then saveOriginally Posted by saurus
thanks all for your replies. i was able to get the chapters to work after all. just a little error on my part on where the chapter times should actually be. :/
BR file has no chapter
By cowboyup910 in forum Video ConversionReplies: 2Last Post: 24th Mar 2011, 11:48 -
Free Program For Creating Chapter Points In DVD Video Without Re-encoding?
By bbanderic in forum Authoring (DVD)Replies: 3Last Post: 7th Mar 2010, 09:17 -
AVStoDVD Chapter help?
By uEih in forum Authoring (DVD)Replies: 0Last Post: 24th Nov 2009, 06:34 -
diving one chapter into several ones
By jony2 in forum Authoring (DVD)Replies: 1Last Post: 13th Apr 2009, 10:26 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 11:51
