Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 9 of 9
  1. Are there any consumer MiniDV cammcorders that can accept different optical lenses? Wide-angle, > 2x Zoom lenses, filters....... Many MiniDV cam only have 10x optical zoom which isn't enough. Sony has a telephoto 2x zoom lense which isn't very impressive and its mounting looks like an after thought. Something similar to changing lenses on a convential 35mm camera.
  2. Member vhelp's Avatar
    Mar 2001
    New York
    hi MachineMan,
    I too am sort of stuck in this area - Sony TRV-22 cam.
    But, all these cams are thread-based. You have to really search out far to
    find any attachments.
    I bought a wide-angle lens at CC because the guy said it would fit. I was
    happy till I got it and to my surprised did not come anywhere's near/close
    to fitting my TRV22. I ended up keeping the lens though, cause it was kind
    of cheap for me at the time, and I still needed to do some experimenting
    and testing (can't do that w/out a WA lens) and nobody really had an in
    expensive lens then.
    What I'm doing is this..
    I'm rigging up my CAM to a board and piggy-backing the lens onto a foam.
    And, what I do is sort of slide it along-side the board, clamp it down (easy)
    and vualla.. instant WA.
    I'm currently testing this out w/ some ideas on my 2.35:1 aspect ratio scenarios.
    Actually, it's comming out quite nicely
    Still, would be nice if they had a Cinema 2.35:1 lens attachment for the TRV22.
    -vhelp
  3. Here are the accessories I found on the SonyStyle web site:
    http://www.sonystyle.com/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/USD/SY_AccessoryCate...var_3=DCRPC330
    The lense doesn't look to have threads and neither do the the MiniDV cams.
    Does your auto focus and zoom work well with your set-up?
    Im looking to buy a new MiniDV camcorder next year that has >3MP stills but want more the 10x optical zoom. I have my eye on the Sony DCR-PC330 which currently overpriced. I want MiniDV for the smaller size so I can easily keep it in a backpack or large pocket.
    Mar 2003
    Largo,Fl.
    Vhelp,
    I have the Sony trv-33. I purchased the Sima wide angle lense from Best Buy and it came with 3 aluminun step down rings, a 30-37mm ( this one fits the trv-33) , a 30.5-37mm and a 28-37mm ring. I think they whole outfit was around $30.00.
    hootie29
  5. Member vhelp's Avatar
    Mar 2001
    New York
    On my Sony TRV-22 . . .
    I don't really like the auto focus. I'ts my opinion that cam equiped w/ an
    audo focus on results in impage artifacts, due to the constant lens movements.
    Final Conclusions: I stopped using it
    ** I get an average weighted (by eye, and experience) and use that
    as my final focus. If I have to adjust the focus, I'll quickly do it via the on
    board touch-screen. Takes a bit of pratice and feel, but once arrived, there's
    no stopping the applications..
    As for the zooming.. its ok, though I'm not sure what issues you are having
    w/ your zooming ??
    I have found that if you zoom at all, you do so w/ some kind of contraption
    or gizmo. I have a motorized Panning toy I found. Really works well. No
    sudden jerks, hence smoother bitrate.
    I'm still working w/ this toy. I want to rig it to adjust the panning speed
    for up/down/left/right movments - or till I find something better.
    Otherwise, leave zooming alone, except for when you are at a given scene
    where you can afford to zoom (if cam is not moving, and not in one's hands)
    -vhelp
  6. Member vhelp's Avatar
    Mar 2001
    New York
    @ hootie29,
    I didn't know about these rings (steps downs) at the time I bought the lens
    (but that's prob why the salesman said it fit, cuse it thought it came w/ those
    rings) But, the lens I bought did not come w/ any.
    I wonder if they carry them separately
    -vhelp
    Mar 2003
    Largo,Fl.
    vhelp,
    I did a search for just the ring and the only place that had it was on Ebay. I don't know if local camera stores would have them or not.
    hootie29
  8. First, the Canon VR series has a relatively wide optical zoom range (18x for the 60 and up to 22x for the 70). Second, they have add-on wide-angle and tele lenses available (in 2 quality levels). I use a VR70 with the wide adaptor lens. It gives a significant increased field of view but results in some curvature of the field (which can be very noticeable if you have a straight line object in the picture). I've had good success with over 15 hours of tape shot in about 6 months.
    Nov 2003
    Calgary, Canada
    I bought a Sony DCRPC9 DV camcorder, Wide angle, Zoom lens and filters all off Ebay separately. The adaptor ring fit both lenses no problem along with 3 different filters. Have had no problems at all. The only thing with the adaptor ring is when you zoom back all the way with the Wide angle you can see the ring, but just a touch of zoom it's gone. Still working on that. Anyways all I did was make sure that the Wide angle and Zoom/adaptor ring matched the camera and had no worries.
