I need help to find a video capture device that will work on my software.
Anyone want to test my software to see if their video capture device is compatible with it.?
It will help me a lot.
you can download it here (it just 2 mb) :
http://www.instashop.net/videoassitprosetup.zip
You can select (if it is compatible) your capture card in the Setting ->Select device-> Select capture Device window
Any help would be greatly appreciated !
I know that the PInnacle DC-10 and DC-30 cards work with my software but i need a device that work under Win Xp ( DC-10 and DC-30 don't work on XP)
I need a video capture device that do Video Overlay (able to loop the video Input to the Output)
My TV in/out on my G4 MX440 is compatible but don't do Overlay
ALex
Results 1 to 14 of 14
Wouldn't it be easier to just use software that works with the card, not vice versa? Or are you a programmer pushing your program? I can't figure out which one.
I need to use a software that is specialized for my job.
I'm a Video Assist operator. I work on Movie and Tv comercial 35mm Film.
Video Assist is a technical position on a film crew.
Since film needs to be processed and printed after it's exposed, it can't be viewed until the next day.
Video assist refers to the video camera attached to the optical system of the film camera, and the technician (me) who records, and plays back the video image immediately. It is strictly a reference for the shoot day, as the real film will be available for viewing the day after the shoot, as dailies.
I try to build a digital Video Assist system for doing instant playback at variable speed and live editing. i need this software to do my work.
I can't use Adobe Premiere or other editing software for doing Video Assist.
This software is exactly what i need but i have to find a video capture card that support it.
I cant buy all video card to test it one by one.
Sorry for my english -
Now that's make a lot more sense.
I oinly wish I could help.
Please i really need help!
Try my software just to see if it work with your video capture card.
It is just 2 mb download.
Thanks in advance!
Alex -
If it's a standalone package, I'll try it... if it requires any kind of installation... no way. My systems work great, I'm unwilling to needlessly install anything these days.
Nope, not gonna do it.. it requires an installl.. I'm not messing with it... if you can provide a no-install version, I'll give it a test...
alx3d,
Same problem with my pixelview playtvpro tv-card as the G4 MX440, no video overlay (able to loop the video Input to the Output)
. It's not easy to support video overlay when only having video input
vcd4ever. -
Canopus ADVC - 100 is your solution. It works with all software!!!!!Originally Posted by alx3d
Jeff -
Tried it with my aopen aeolus geforce ti4200 128 mb video card with vivo and it works great.
hiptune?
Do you have tested my software with this card?
I know tha my software use AviCap32.dll Video for Window (VFW) to detect a capture video device.
I send a email to Pinnacle to ask if they have a video capture card that will support my software
Here is the reply from Pinnacle:
AviCap32.dll is a very archaic Microsoft generic video for windows API for capturing video. Microsoft no longer supports video for windows so you will not find any current hardware that uses VFW calls. The last hardware that I am familiar that used VFW was a targa 2000 using adobe premiere 4.0. You may be able to find a similar solution on e-bay for a few dollars used, but you'll be running windows NT.
Obviously we do make solutions for capturing and editing video. In the end, the limitation is going to be your custom software.
I hope this answers your question somewhat.
Craig
>I have a home maid software that do all feature that i need to do Video Assit fonctions.
>Is there any of your capture device that are comapatable to accept calls >from a software using AviCap32.dll for windows XP?
ALex -
No, that is up to you to do, you are the one being paid, now get to work!Originally Posted by alx3d
Jeff -
I'm not paid to do this. I'm a self-employed and i do this for myself. I dont have the money to buy a video card just to see if it work.
Thank's to all that help me!!
Alex -
Alex, that is the thing about the Canopus ADVC-100, it always works. There is a thread going on right now started by Lordsmurph about why the ADVC-100 is so popular?Originally Posted by alx3d
It is because it never conflicts with software, it has no drivers, it simply suports analog into hard drive via firewire 1394.
Jeff
Cant get either video capture card to work
By ralphey in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2011, 21:02 -
Trying to select PVR software for my capture card.
By GLE3 in forum Capturing and VCRReplies: 7Last Post: 14th Apr 2010, 19:03 -
Trying to find Capture Card - w/ Component input
By tS_veXed in forum Capturing and VCRReplies: 63Last Post: 21st Nov 2008, 08:08 -
trying to find the best capture card!!!!
By owen_o_we in forum Capturing and VCRReplies: 13Last Post: 4th Sep 2007, 23:39 -
Would an older capture card work on a Vista PC?
By Rein Engel in forum Capturing and VCRReplies: 15Last Post: 23rd Jun 2007, 12:33
