I have a Nec Nd-1100a. I have been burning Optidisk and Memorex, which work fine. Then I tried Verbatim, it burnes fine but the problem comes when playing. It always messes up within 30 minutes. All burning is done with Nero. I was wondering if, the problem was the media or the burner.
It could be a bit of both - some recorders adopt a better write strategy than others when it comes to media that's borderline with your equipment.
However, to be borderline, the media has to be right on the edge of your player's compatibility anyway. It definitely sounds like a media issue - check out who really made your blanks with something like DVDinfo Pro or similar, and stick with a brand you know works.
No doubt someone will blame Nero, but I use that exclusively and have never had any problems with it that were not of my own making. But I've had my fair share of media that won't play in my standalone... -
I never use nero to burn any dvd. It suck (at least for me). I had a whole bunch of playback problem. It would freeze, skip, pissed the hell out of me. Using the same drive and media, i used dvd decrypter and everything has been working fine eversince. Remember, what might work for someone might not work for other, so try different method. GOOD LUCK!
I have tried dvd decrypter, and still the same results. I think I got some sorry dvd+r's
firmware burning problem
By weedhopper in forum DVD & Blu-ray PlayersReplies: 6Last Post: 1st Aug 2010, 12:34 -
Problem with burning.
By googoodolls in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Dec 2009, 07:20 -
Convertxtodvd burning problem
By kulkul in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jun 2009, 21:24 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 13:39
