Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. mail2tom
    Guest
    I've been working with two 2.1Gig MPG files, attempting to run them through SVCD2DVD, but have not been able to get the process to complete. Is there a maximum file size that any of the components of SVCD2DVD will stop at? Thanks.
  2. DaveDavies
    Guest
    not sure if this is the problem but are you using ntfs or fat32 on your drives, I think I'm right in saying fat32 can't handle more than 4gb files.
  3. Originally Posted by DaveDavies
    Your right..
    Greatings,
    Yf
    Oct 2003
    The Netherlands
    Your right..
    But that's not the problem, is it? I use WinMe, so I also have a maximum of 4 Mb, but that doesn't keep me from making 4.4G DVD's. As long as I do not try to make a 4.1 Gb input file.
    The output isn't a problem either, as the VOBs are 1024 MB at most.
    I also had some troubles with largish input files, say 1.8 to 2.0 or more Gb. I reported on it, but never got a reaction. I must look up the subject line..
    Callan
    It was "Curious SVCD2DVD Behaviour", submitted on 25 October 2003.
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    >2GB should be ok I updated various things to support it a while back. I shall recheck however as its not the kind of thing i do...
