I can get this to make an mpeg straight away which saves the virtual dub and tmpeg longer route for files that quality is not a fundamental. The only thing is there is no sound on the resulting file. It says in the options that the creative live 5.1 is the recoding device and I have tried via the microphone as well as line in but no joy. I hear the sound OK though when recording.
There is no audio problem recording with virtual dub or any other program (asus live vcr, windows recorder etc etc etc)
Is there any issues with powervcr ?
anybody using this and getting it to work ?
scattergun
capture card is
asus 7700 delux
system is 1.3 Athlon Tbird, 40 gig 7200 rpm hd - 10 gig partition for captures - frequent defrag.
1.5 gigs ram (limited to 512 megs in vcache)
creative 5.1 pro soundcard.
I have no problems with any other applicationwhen capturing audio - with or without video, only with power vcr
scattergun -
i also have the same problem. i cannot record audio. i used asus 6800 for video and soundblaster for audio.
MKV2VOB sound problems
By DaxPG in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2010, 15:43 -
Sound problems
By maltipom in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2009, 13:37 -
sound problems
By deebo in forum Software PlayingReplies: 4Last Post: 9th Aug 2008, 14:43 -
Sound problems
By zewzeq in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 20th Nov 2007, 06:36 -
avi2dvd sound problems
By justmenow55 in forum Video ConversionReplies: 5Last Post: 13th Aug 2007, 02:58
