Hello all,
I have a Pioneer DV525 and have problems with VCD menus
created with both Nero 5.5 and WinOnCD 3.8PE. While
my player correctly displays the first menu screen,
hitting the "Next" button on the remote or on the player
does not advance to the next Menu screen in PBC mode
(e.g if I have many items in the Menu, I'll have multiple
menu screens and I can't access screens 2, 3, etc.)
While I can't access the other menus, the VCD or slideshow
plays just fine (e.g. all play items are okay) with and
without PBC enabled.
Anyone have a tip on how to work around this? Is there
a Nero or WinOnCD setting to fix this? Or is it a software
bug? or is it basic DVD player incompatibility that I
need to live with?
Thanks,
Kevin
Hi,
I've also made a number of VCDs and SVCDs with menus
using Nero.
In the meanwhile, I think I found a problem in Nero menu.
When I created a menu with bitmap files, Nero did it fine.
But when I played with .jpg files to creat the menus (Nero
recognizes .jpg files fine!), the results ended up the same
problem you had.
Hope this may be of some help.
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 03:44 -
Menus folders or sub-menus
By GymDad in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 9th Nov 2008, 08:43 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 14:16 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 11:07
