Good morning Everyone,
I am trying to check some XVID movies for bad frames becasue when i converted them to DVD and played them on my DVD plyer using TMPGenc they had some "freeze's" or "Choppy Spots" every so often. I am trying to check them for bad frames using Virtual Dub. Every time i try and open the file i get that XVID is not reconized. I downloaded and installed again the Xvid codecs from http://www.xvidmovies.com/codec/ and it still says that. Can someone let me know what they are using to open XVID in virtual Dub? Maybe these codecs are not the correct ones. I am using XP also...
Ohh i also forgot to ask.....If there are bad frames does that mean when i play the movie on my computer that i should see the "freeze's" also? becasue i went back and played the XVID on my PC and i went to the certian spot in the movie that it had that "freeze" happen while playing on my DVD player and it did NOT happen on my pc? is that normal?
Thanks -
So, that it plays fine as AVI using a media player says almost nothing.
Try ffdshow to get XVID playback/decoding working, and if that fails, use the four cc changer.
/Mats -
Thanks Mats. Do you know why Virtual Dub will not reconixe that XVID movie? i really really want to get it to work. any ideas?
You may also want to try a later version of Virtual Dub mod. Also, if TMPGEnc will accept the file, try loading it there, file a template similar to it, and select Output to file -- > AVI. This is a hit-and-miss option, as it may not give you good quality, and it just might.
Hello. -
i still cannot load ANY XVID movies in birtual dub. is there any other tool out there to check and or repair bad frames?
I fixed it....I was using the WRONG codecs....Thanks for all your help....and thanks for not telling me to "read the guides" I HATE that....
Thanks again
virtual dub não abre arquivos cokm codec xvid
By sandroguchilo in forum AudioReplies: 3Last Post: 14th Dec 2010, 16:43 -
Working with Subtitles on a 64-Bit System: XVid, SUPER, & Virtual Dub
By jdanniel in forum SubtitleReplies: 17Last Post: 22nd May 2010, 13:08 -
virtual dub xvid codec encoding w/o profile
By caner12 in forum EditingReplies: 7Last Post: 5th Jul 2009, 12:08 -
xvid encoding in Virtual Dub, stats file?
By Xavier in forum Video ConversionReplies: 4Last Post: 10th Feb 2009, 08:46 -
how to set max bitrate(xvid virtual dub)
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Feb 2008, 08:54
