Here I am still floundering around trying to do this (I thought I was smart when I bought a DVD-RW to test my attempted encodes...but none of my DVD players will accept it!)!
Anyway,my confusion is mostly over aspect ratios and the like.
I have 2 XVID's....one is 608x256 and the other is 576x320.
I followed the TMPGEnc guide by Baldrick and unless I missed something there seems to be no mention of the "setting" of aspects (other than the defaults).Although I do have to say that my version of TMPGEnc is a little different than the screen shots...(ie:the wizard only offers NTSC (not NTSC and NTSC 16:9).
This is where I get mixed up .
If I want the end result to work on my new widescreen TV,it seems that the guide only refers to 4:3 (at least going by the screenshots anyway).
I would very much appreciate if someone could explain (in your best "dumbo" laymens terms for poor little wee-haggis) what my basic settings should be.
Thanks a bunch.
"Today is only yesterdays tomorrow"
First, please do not bump your posts for at LEAST 24hours.
Now on to your question.
In TmpGenc, try the following settings (you may have to set these manually, I have never used the wizard!)
On the advanced tab of settings:-
Source aspect ratio, 1:1 (VGA)
Video arrange method, Full SCreen (Keep aspect ratio)
On the Video Tab:-
Aspect ratio - 16:9
This should give the correct aspect ratio for MOST Divx/xvid videos to be played on a widescreen TV. -
Sorry about the "quick" bump.....*smack*(just slapped by knuckles with a ruler).
And
Thanks for your suggestion .I will give it a try."Today is only yesterdays tomorrow"
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Am totally confused with dvd film conversion.
By frenchman96 in forum Video ConversionReplies: 6Last Post: 10th Nov 2010, 09:38 -
sync issues with DVD to DivX conversion
By snafubaby in forum DVD RippingReplies: 12Last Post: 24th Dec 2008, 02:10 -
confused with divx files that work
By ceve4life in forum Authoring (DVD)Replies: 3Last Post: 30th Jul 2008, 16:42 -
DivX to Mpeg -> DVD Conversion is Jerky
By jedijfo in forum Video ConversionReplies: 4Last Post: 15th Oct 2007, 08:32
