  1. Anonymous
    Guest
    Tried to convert 2 parts of the video .mpg files as usual, and have done many times, but this time comes up with the following log error. It crates the first dvd.mpg file fine but not the second one?
    ############### New MPEG File ###############
    File: G:\Received Files\Once Upon A Time In Mexico\Once Upon A Time In Mexico CD2.mpg
    Type: SVCD
    Horizontal Res: 480
    Standard: NTSC
    Audio SampleRate: 44100
    ******** Demultipexing original mpg file
    bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
    speed increases by, Apachez and Christian Vogelgsang
    Saving stream 0xE0 into file G:\Received Files\Once Upon A Time In Mexico\Once Upon A Time In Mexico CD2_DVD.mpv...
    File G:\Received Files\Once Upon A Time In Mexico\Once Upon A Time In Mexico CD2.mpg is an MPEG-2 Program Stream
    Summary:
    MPEG Packs = 294765
    System headers = 1
    Padding Stream packets = 2, total bytes = 2698
    MPEG Audio stream 0 packets = 31938, total bytes = 73233834
    Video stream 0 packets = 262826, total bytes = 603483506
    Saving stream 0xC0 into file G:\Received Files\Once Upon A Time In Mexico\Once Upon A Time In Mexico CD2-0.mp2...
    Summary:
    MPEG Packs = 294765
    System headers = 1
    (Total size: 653MB, Duration: 00:03:01, Rate(MB/Min): 215.68)
    ******** Resampling audio from 44.1 KHz to 48 KHz
    (Total size: 69MB, Duration: 00:00:00, Rate(MB/Min): 13,248.00)
    ******** Multipexing elementry streams
    INFO: [???] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
    INFO: [???] File G:\Received Files\Once Upon A Time In Mexico\Once Upon A Time In Mexico CD2_DVD.mpv looks like an MPEG Video stream.
    **ERROR: [???] Unable to open file G:\Received Files\Once Upon A Time In Mexico\Once Upon A Time In Mexico CD2_DVD.mpa for reading.
    System.IO.FileNotFoundException: Could not find file "G:\Received Files\Once Upon A Time In Mexico\Once Upon A Time In Mexico CD2_DVD.mpg".
    File name: "G:\Received Files\Once Upon A Time In Mexico\Once Upon A Time In Mexico CD2_DVD.mpg"
    at System.IO.__Error.WinIOError(Int32 errorCode, String str)
    at System.IO.FileInfo.get_Length()
    at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
    at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
  2. Anonymous
    Guest
    Found the problem, Avast AntiVirus blocks the cygwin1.dll when converting the second .mpg and it won't complete.
    Turn off Avast and it works fine but not comfortable about having no AV running even for 15 minutes.
