Hi!!
Does anybody have any idea how to author DVD -format MPEG2 files to DVD-RAM's .VRO -format?? I've tried to search the web for an answer but i came up with nothing.
DVD-RAM home-players wont recognize the standard file structure that you use normally with DVD+-RW discs.
Can you just merge the files to a big one and rename it to .VRO?? problem here is that the disc has a header file .ifo. can you reproduce that in some way that it matches the merged .vro file??
Has anyone done anything similar to this? I would be grateful for any information![]()
1. Ulead MediaStudio Pro 7.01 (pro):
http://www.ulead.com/msp/runme.htm
2. Ulead VideoStudio 7.01 (home user):
http://www.ulead.com/vs/runme.htm
Both of the above applications feature DVD-VR Export Wizards that write to the .VRO file format.
Both of the above applications will also grab raw MPEG video/audio from DVD-RAM discs recorded in popular player/recorders.
I wrote a step-by-step tutorial about how to do this using Ulead MediaStudio Pro and the Toshiba D-R1 player/recorder:
http://www.jonesgroup.net/msptoshibastepone.htm
Only Ulead MediaStudio Pro supports AC-3 audio along with MPEG AUDIO and LPCM AUDIO.
Ulead VideoStudio supports only MPEG AUDIO and LPCM AUDIO.
By the way, my Toshiba D-R1 will read and record to DVD-R and DVD-RW discs as well as DVD-RAM discs.
So one should be able to author a typical DVD with .VOB files in Video_TS folders and the resulting disc will play just fine in the Toshiba model of player/recorder.
Hope this helps,
Jerry Jones
Editing Panasonic Burner DVD-RAM VRO Video In Computer
By Teshia in forum User guidesReplies: 47Last Post: 18th Feb 2013, 08:06 -
Problems copying .VRO files from DVD-RAM -- SOLVED!
By usually_quiet in forum DVD RippingReplies: 14Last Post: 2nd Jun 2011, 16:30 -
RAM .vro files to usable format?
By nelsh in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2007, 19:05 -
DVD-RAM to DVD / DVD-VR to DVD / VRO to DVD
By Baldrick in forum DVD & Blu-ray RecordersReplies: 6Last Post: 16th Sep 2007, 03:49 -
Extracting .VRO file from DVD-RAM to pc for editing
By mattsz in forum Newbie / General discussionsReplies: 9Last Post: 13th Jun 2007, 13:25
