Hey people, can you guys give me some help: I would like to back up some of my DVDs onto SVCD/VCD since blank DVDs are a little bit too expensive for me. What is the easiest method that you could recommend?
Originally Posted by smithnya
I'm sure there are guides here on using DVD2SVCD although the few times I used it I think I followed a guide that was on the DOOM9 website.
Even if you use DVD2SVCD you still need either CCE or TMPGEnc as that program merely "sets" things up for you but makes use of one of those programs.
- John "FulciLives" Coleman
P.S.
I would stick with SVCD as VCD quality is not very good. But if you have a DVD burner ... well ... that will give you MUCH better quality than even SVCD"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Another method that worked well for me: Rip with cladDVD.net, frameserve with DVD2AVI, encode with TMPGenc. There's a guide for it, can't remember by whom, do a search on clad in the guides and look for the one that uses the other tools as well. Easy and free, except SVCD capability is limited to 30 days with TMPGenc, then you must buy it.
Pull! Bang! Darn!
What's the easiest way to convert a PAL DVD to NTSC?
By snafubaby in forum Video ConversionReplies: 3Last Post: 26th Mar 2012, 20:21 -
The easiest way to convert dvd to mp4
By karib in forum Video ConversionReplies: 2Last Post: 8th Feb 2011, 16:01 -
Fastest & easiest way to convert files from dvd to upload to Youtube?
By scarypoultry in forum Video Streaming DownloadingReplies: 2Last Post: 6th Jul 2010, 02:49 -
Easiest way to convert HD-DVD to Blu-ray?
By DGenerateKane in forum Blu-ray RippingReplies: 4Last Post: 27th Sep 2009, 17:04 -
Easiest way to convert episodes from a dvd to single episode files?
By Pj10 in forum Newbie / General discussionsReplies: 6Last Post: 21st Dec 2007, 21:42
