Results 1 to 11 of 11
  1. i've been using tmpeg for more then half of a year and
    i've had no problems with it all all...
    untill now,
    I was backing up one of my dvd's to svcd,
    when all of a sudden my computer blinked out
    and restarted, i thought nothing of it...
    then i restart tmpeg, and try to load the d2v
    and i get this alert message
    'file "blah.d2v" can not open, or unsupported'
    now i've never seen this message ever in my whole
    encoding life, so it freaks me out
    can anyone shine some light on the subject,
    so i can get back to my encoding?
  2. What version are you using ? A mate of mine has experienced something similar to this !
    Try downloading the latest version from mpegx.com
    <font size=-1>[ This Message was edited by: Generator on 2001-10-12 13:30:52 ]</font>
  3. that is the latest version =/
  4. Do you have anything running on your system that may be conflicting, another encoding programme etc ?
  5. nope, not a thing
    this has never happened b4 untill now
    and i didnt install anything new
    or reg any new dll's or files
    im confused as hell =/
    gateway to the west
    from the way it sounds, the file became corrupted when the system rebooted. Of course the question is what made the system reboot. There are many factors in that one. You might have to rip the file again, also you may want to reinstall tmpgenc just for good measure. Did you let scandisk or another program scan the drive for any corrupt files? There could also be a bad spot on the hard drive and that is what caused the system to drop out and the file corruption. Which there again is a good idea to scan the hard drive also check how fragmented your drive is.
    These are just ideas.
    TW
    France
    Maybe this is a VFAPI plugin problem ? Check it is active in TmpgEnc... Check your DVD2AVI VFAPI plugin too... To be sure install both tmpgenc+VFAPI & DVD2AVI+VFAPI in the same folder ... Maybe that's the problem...
  8. i found the problem,
    direct x was for somereason uninstalled or corrupted
    scared me for a sec.
    thx for the advice tho
    gateway to the west
    that will do it. LOL. Glad you found the problem. I know stuff like that will drive you up the wall til you find it.
    have a great day.
    TW
