  1. The reason I was asking is that I have the RP-62 Panasonic in the living room and the Sanyo DWM-395 in the bedroom....and i'm about to purchase a DVD writer for my pc and have found that my RP-62 accepts +r and +rw but I can find no info about the Sanyo....If the Sanyo accepts +r and +rw then I can save some cash by buying a burner that only does +r and +rw burning.......any info would be appreciated......thanks
  2. Member jaxxboss's Avatar
    Apr 2003
    JAX, FL
    You wont be saving that much cash. Also, how do you even know that the sanyo will even play a -R let alone a +R ?
    You need to find out first either way. Buy the +R burner and if the sanyo wont play it then you can always return it for a dual format burner, Im sure they would be happy to exchange it if your moving up a bit in price.
  3. Bought one at Walmart for my son, checked everything, plays DVD+R in both book types (DVD+R and DVD-ROM), - R and +RW .Didn't check - RW. I check DVD-R made with my Panasonic E30, and won't play,all others -R played OK
