EDIT - Trying to follow through this guide entitled "Convert AVI to DVD & AC3 with CCE and AC3Machine", and now I have NO AUDIO in my final built image with imgtool...see fourth message...I have followed the article to the letter.
thx in advance.
DivX uses square pixel resolution whereas DVD does not. Full screen for DivX is 640x480 but full screen for DVD is 720x480Originally Posted by midimidi
So use:
LanczosResize(720,480)
and don't use the AddBorders command.
Sounds too simple I know but it will work. Now if your DivX has a resolution other than 640x480 then that is another story.
THANKS!
I got all the way through the article, but when I load my m2v into TMPGEnc DVD Author, I get the error:
The video GOP is too long.
blah blah must be in the following condition:
Max 36 fields (18 frames) - NTSC -
What encoder were you using? TMPGEnc or CCE or Mainconepts etc?Originally Posted by midimidi
I made this mistake once with CCE but it is hard to do with TMPGEnc unless you used the wrong template or didn't follow the WIZARD MODE or did something really wrong
I used CCE - followed the article to the letter!!
I found some other posts stating similar problems with the process, so I went ahead and built an image in imgtool for testing. My problem NOW is there is NO audio! I use WinDVD for playback, and it usually plays ac3 just fine through my main out. I tried playing the ac3 file alone in WinDVD, but I get nothing. The wav file does have audio....very confused!!! What am I doing wrong? -
OK - what about this. On the step where I save the wav file in VirtualDub:
When I open the avi movie in VirtualDub I get the following error:
VirtualDub jas detected an improper VBR encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 31182 ms of skew from the video stream. If this is unacceptable, decompress the entire audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder. (bitrate: 120.4 +/- 26.0 kbps). -
If you are saving to wav using audio->full processing doesn't that error msg matter.Originally Posted by midimidi
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
LordSmurf's XVID Guide
By Torrential in forum EditingReplies: 3Last Post: 19th Mar 2009, 07:34 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 02:01 -
Guide for creating Divx/Xvid DVD Rips Easily on a Mac?
By ehmjay in forum MacReplies: 4Last Post: 7th Oct 2008, 18:03 -
Guide for downsizing xvid files?
By bogart219 in forum Newbie / General discussionsReplies: 5Last Post: 11th Oct 2007, 06:35
