hey just got a new dvd burner from best buy-a lite on.
it claims to be a 4x for +/- dvdr's.
its working fine but is taking about 70mins to burn a dvdr movie.
my buddies all claim to be doing the same in about 15 minutes with their pioneer a106 which burns at the same speed. Is something wrong with my drive ? It sounds like its burning at 1x.
my set up
amd 1.1gig\gigabyte md
1 gig sdram memory
win2k w hdd ntfs
Lite On Internal DVD±RW/CD-RW Drive
Model: LDW-411S
using recordnow dx software to burn a 4.7 .img
Results 1 to 11 of 11
What media are you using? If you have -R it could be 1X to 4X if you are using +R it could be 2.4X to 4X
Check to be sure DMA is enabled on the IDE channel you have the DVD on in device manager.
Go here and download the latest firmware if you havent already,it will let you burn more brands better,especially dvd-r.
http://www.liteonit.com/ODD/english/english-load-firmware.htm#LDW -
that didnt work and windows could not find the device,Originally Posted by jtommyj
opened my computer and it wouldnt show anything at all,
opened recordnow and it froze up as well. tried to reset it back
to pio and the device manager froze up...ahhgh!
pretty sure the mb supports dma, the primary ide uses it for the hdd...
wtf? -
download the utility from lite on smartburn.exe I don't think it supports this media disc
fixed
took out the drive, looked at the jumper, was set to slave, always thought default was master, set it to master, removed old cdr drive, re installed it, set to dma, burned dvdr in 25 minutes now, never used flash rom, rad...
thanks for the help and suggestions
btw the fuji 4x dvdr+ works perfect in my jvc and pioneer 6 disc dvd changer and my dell laptop. -
that sounds like 2.4x burning...Originally Posted by bruceleroy
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
90% of the time if there is an update to your firmware or a software package, you should DL and install.
Hey, that product you just bought might have sat in a warehouse for 3 to 6 months. The company's programmers have been tweaking the drivers or the ROM all that time and you decide, Well, it works good enough, I won't update.
Please do.Then you'll be answering questions here instead of asking them.
Join the club. You'll be happy you did.
Cheers,
George
And, as tompika says, maybe you are happy because you don't know any better. A 4X burn is in the 15 min neighborhood. -
Just bought this burner and updated the firmware. It burns 4x +R in about 14 minutes, 2.4x in around 25 minutes
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 18:55 -
How do I burn a dvd with nero using ffdshow from k-lite pack
By sxpredman in forum Newbie / General discussionsReplies: 7Last Post: 7th Nov 2009, 02:20 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 19:28 -
Burn AVI Video to DVD at different times onto one DVD
By 98xlt98 in forum Video ConversionReplies: 2Last Post: 18th Mar 2008, 09:58 -
Burn Times 3x longer after I installed AutoGK
By Gunewbie in forum ComputerReplies: 6Last Post: 19th Jul 2007, 22:45
