Below is the message I receive when I load certain avi files...
"Virtualdub has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. THis may introduce up to 243015 ms of skew from the video stream. If this is unnacceptable, decompress the *entire* audio stream to an uncompressed wav file and recompress with a constant bitrate encoder. (bitrate: 128.1 + 28.2 kbps)
What do I need to do to make these files work on virtualdub???
Thanks,
"Hark"
Closed Thread
Results 1 to 17 of 17
You could extract the audio, using Gold Wave, and save it to wave. Then load the original video, and use the new wave file as audio.
Hello.
Extract the audio as .wav in virtualdub.
Resync audio as in this guide (works for avi as well as mpeg): http://club.cdfreaks.com/showthread.php?s=&threadid=59487
You can then save the fixed audio, and remux during authoring, or encoding.Cheers, Jim
My DVDLab Guides
Check out my tip here for MP3 and AC3 audio with VBR
http://www.fixya.com/support/r4099743-set_virtualdubmod_align_audio_frames
VBR MP3 is not a problem in the new versions of Virtualdub. If you get a message in the new versions then turn it off. Under Options > Preferences > AVI, untick box next to "warn when VBR audio is detected".
Look above Darth Paris post-
14th Jun 2004 19:57 The date is right above your name.If not then somethings wrong with your settings in this site.I think,therefore i am a hamster.
Interesting. Since the forum change, on this computer I've seen no dates at all, other than the join date. But when I just checked on a different computer, they're there, just like before. Could the difference be caused by this computer using old Internet Explorer 6 and the other one using an up-to-date Mozilla Firefox?
I didn't see a date in my browser either.
That said, once the thread is brought back up, you might as well put in the correct answer for anyone else looking at the thread instead of just telling people not to post in it. Some people think it's easier to reply to a thread that's already started than to start a new thread on the same subject. Also, once the thread is brought back up then it will appear in Google on a search query just like this one is at the top of the list so telling people not to respond is not going to deter all the users on Google who are looking for an answer.
By lingoguysw5 in forum AudioReplies: 17Last Post: 26th Oct 2009, 10:12 -
Error While Encoding Audio On VirtualDub
By ashwin.terminator in forum Newbie / General discussionsReplies: 3Last Post: 18th Oct 2009, 09:00 -
VirtualDub 1.8.6 = Error about Audio (VBR) ??
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 28th Oct 2008, 10:55 -
virtualdub has detected an imrpoper vbr encoding...The current preference..
By von_25 in forum Newbie / General discussionsReplies: 11Last Post: 25th Mar 2008, 01:57 -
VirtualDub crash involving Huffyuv
By Xoanon in forum EditingReplies: 4Last Post: 15th Jun 2007, 17:33
