Results 1 to 15 of 15
    Feb 2003
    USA Heart of Dixie
    How can I place a little whirrlygig or cartoon under my screen name, like so many others have here ?
  2. You gotta make an avatar. Its gotta be a certain dimension and size. If you look in your profile part, at the very bottom it tells you these sizes and dimensions.
    Just resize a picture you want and make sure its not larger then it says and upload it.
    Hope this helps
    Hatz
    Loves the funeral of hearts.....
  3. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    At most it can be 80x80 pixels and 6k
    Feb 2003
    USA Heart of Dixie
    How do you resize it ?
  5. Mod Neophyte redwudz's Avatar
    USA
    Try this website:http://www.animfactory.com/, for animated gifs.
    They have the gifs there and a simple on line program that lets you resize and change the colors of the gifs. I never had much luck resizing, as the quality generally suffers. For more variety, type 'animated gifs' into a search engine such as Google.
  6. If it is a still picture or hell....maybe even an animated pic, you can resize it in Photoshop if you got it. You can do it in MS Paint as well.
    Hatz
  7. Member Devanshu's Avatar
    May 2003
    Hatz
    I dont recommend you do it in paint...it'll turn out pretty bad. If you dont have any other image editing programs, then go ahead...
    Feb 2003
    USA Heart of Dixie
    I see what you mean about paint, but it was all I had. But now I appear to have a little personality.
    Coffee makes you happy.....Except when it messes you up
  9. Member Devanshu's Avatar
    May 2003
    Here's your resized avatar without all those little dots...
    Feb 2003
    USA Heart of Dixie
    Devanshu.
    Thank you buddy. Nice Christmas gift.
  11. Member Devanshu's Avatar
    May 2003
    Originally Posted by CoffeeGuy
    Devanshu.
    No problem...now you owe me one
  12. Originally Posted by Devanshu
    Devanshu.
    i do 1 for u
    heh...
  13. Member Devanshu's Avatar
    May 2003
    Devanshu.
    i do 1 for u
    heh...
    https://www.videohelp.com/forum/viewtopic.php?t=176230
    :P
  14. "if it's possible, you probably need to chip your gc"
    :P
  15. Member Devanshu's Avatar
    May 2003
    :P
    dont remind jeex.
