Hey people can anyone tell me the difference between DVD-, DVD+, and DVD-RAM without getting too technical?
I have one bit of wisdom. Check what standalone you use and go from there.
The most dangerous thing one can do is eat Banquet chicken in the dark. -
DVD-RAM is somewhat Panasonic proprietary. DVD+ and DVD- are virtually the same--they're just competing formats. Go with a multiformat DVD burner and you're safe. I try to avoid DVD-RAM, although my DVD recorder uses it (unfortunately) and my DVD burner can't read DVD-RAM (although Plextor and someone else now makes DVD burners that can).
Hope this jumbled explanation helps a bit.
-Brian -
To further muddle things, -R is really all you need. You'll get the most compatability with standalone players. MS doesn't seem to like it, I'm sure that has to do with X Box copying. -RAM is nice for general computer/data stuff, more versatile than DVD-/+RW's.
I agree with going -R for everything, but you lost me with DVD-RAM being "more versatile." How so?
I'd go DVD-RW or DVD+RW for sure, as those are common, accepted formats. DVD-RAM is improving, thanks to the new multiformat DVD burners using it, but still not as common as +/-RW. -
DVD-RAM is the best of the three formats, it's also the most incompatible and most expensive. Whereas the two main formats (plus and minus R) use similar technology to CDR, DVD-RAM is much closer to minidisc. This means that RAM has basic editing facilities built-in (for topping and tailing, etc) and you can recover and reuse any spare disc space from, say commercial breaks. Also it allows for Timeslip, where you can start watching a recording before it has finished! For most write once applications, Minus-R is the way to go.
Matshita DVD Ram UJ851s not recognizing blanc dvd
By ezradallas in forum ComputerReplies: 7Last Post: 12th Mar 2010, 12:50 -
Converting DVD-VR (DVD-RAM) with Multiple Tracks
By alexs77 in forum DVD RippingReplies: 2Last Post: 26th Dec 2009, 04:27 -
HOW to DVD-RAM on PC so that it plays in my PANA DVD Player
By saxon22 in forum Authoring (DVD)Replies: 21Last Post: 18th May 2009, 08:34 -
dvd recorder with dvd-ram, no hdd, gemstar tv guide, atsc or ntsc tuner.
By 84transam in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Nov 2007, 20:55 -
DVD-RAM from Panasonic ASTC recorder to PC for DVD authoring?
By Philbiker in forum Capturing and VCRReplies: 2Last Post: 30th Oct 2007, 18:42
