My friend (who has a PC) got some video files from someone. I am trying to burn these as a VCD, or atleast veiw them. Some are WMV and some are AVI. I can't view them using Quicktime or Windows Media Player. I tried just dragging one into Toast 6 as a vcd, but toast wouldn't load it.
Could someone tell me how to burn it as a vcd please
Friends don't let friends use Windows!
Elisha Cuthbert is so a total schorchcake!! -
im surprised about the .avi files not working
do they play in VLC or mplayer osx with no problems?
also try the .wmv in mplayer osx it it will play you can convert it to .avi and then to mpeg
but the question is why the .avi isnt converting.
download mpeg2works and give that a try for .avi to mpeg - should work.
if it does, and the .wmv's play in mplayer, its a simple terminal code to get those to .avi then you can use mpeg2works to get them to .mpeg -
it doesn't play in VLC, and when I open mpeg2works, it won't let me choose any NTSC options, all that I can convert to are PAL.
Is there something else I can use to convert .avi or .wmv to mpg so I can burn as a vcd?Friends don't let friends use Windows!
so you click on the NTSC tab and those optoins are all greyed out!?!?!?!?
if your .avi file doesnt play in VLC or Mplayer properly then you should start to suspec the file being bad!
now do any of the .wmv's play in mplayer? if so they shoudl be able to be converted to .avi and then the .avi to .mpeg2 via quicktime mpeg2 export, mpeg2works, ffmpegx etc
but it will only work with VALID divx files. i dont think mpeg2works handles doctored files.
3D mkv file conversion help
By mkv2avi in forum Video ConversionReplies: 4Last Post: 12th Jan 2012, 11:05 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 10:50 -
Conversion from VOB-File into a MP4 File stopps after 9 minutes...
By Fly Eagle in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2009, 11:41 -
.ts file conversion help
By stanislawski in forum MacReplies: 1Last Post: 23rd Jul 2008, 08:06 -
Help! .mts file??? conversion?
By kalebsmith10 in forum Video ConversionReplies: 6Last Post: 3rd Jun 2008, 17:52
