This is my first attemp at a full movie vcd.
I am trying to convert this file to a xvcd or svcd.
I want very good quality.
THe original avi is good but not the best at times. It is clear but gets blocky sometimes (mostly during fast action scenes)
the info I got on virtual dub is this :
My big question is should I try this as a xvcd or svcd?
what resolution would this convert to ok? It is an odd size isnt it?
What bitrate? I dont care if its on 2 or 3 cd's the movie is T2 it is 2h 16m long.
I dont want it to be too thin like a small letterbox.I have tempge 12...and virtual dub.
any help appreciated.
thanks
Cant anyone help me? I am watching a 5 minute clip i made and it is crystal clear in parts but gets blocky in parts too.
I think its standard resolution for an xvcd 352 x 288
any better ideas? -
If your original avi file is blocky in some parts, it may be difficult to correct it with TMPGEnc. Unfortunately the source file is your biggest issue, so if you can, try to get another better copy of it. if not, try 2 pass variable and in advanced check the box that says soften block noise. It may improve a bit, but again not by much as your source file is the real problem. I had the same problem with "The Abyss", the source file was blocky and I could not correct it without compromising quality of the overall movie.
upconvert DVD player for hi-res DivX video?
By joecass in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Apr 2011, 20:27 -
Can't convert avi to an avi that the my divx player will read.
By aarelovich in forum Video ConversionReplies: 5Last Post: 4th Feb 2010, 06:19 -
Apple Pro Res HQ .mov convert to Huffyuv .AVI
By christianolovesvideo in forum Video ConversionReplies: 8Last Post: 6th May 2009, 14:30 -
Samsung HT-Z310 and Hi Res Xvid / Divx
By TooterDon in forum Newbie / General discussionsReplies: 1Last Post: 23rd Sep 2008, 18:17 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 11:26
