  1. Winny
    Guest
    Since the latest update to AV from www.avast.com reports cygwin1.dll infected with Win32.Trojan-gen.
    Sounds like it could be a generic false alarm, so have mailed them to let them know. Will let you know as soon as I get a response.
    Can anyone confirm the false alarm with another AV product?
  2. Well my system is scaned every night by Mcafee 7.0 pro and that aint thrown anything up.
    Not bothered by small problems...
    Spend a night alone with a mosquito
  3. DaveDavies
    Guest
    Can confirm that my Avast shows the same problem, cygwin1.dll showing as a trojan.
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Interested to see what they say. My protection suite doesn't have a problem with it.
    If you install the latest cygwin from www.cygwin.com SVCD2DVD will overwrite cygwin1.dll that is bundled with the one from cygwin.
  5. still no luck.
    have overwritten the cygwin file, now app is inop and getting an error from the auto update asking if i'm connected to the internet.
    would like to re-d/l the app and reinstall but getting a server error as well. hope it's not me...
  6. from the guys at Avast:
    you are right, it's a false alarm. The file is the cygwin library in
    fact. Thank you for notice us, we'll repair it ASAP.
    Regards,
    Karel Divis
    Virus analyst
    Alwil software
