Hi,
I am having great difficulty in getting SVCD2DVD to create my DVD folders.
I have tried several times using different MPEG's, last time I converted my MPEG's to SVCD using TMPG just to make sure they would be compliant but SVCD2DVD still seems to be having trouble with them even though they play fine on my PC.
Here is the last log file info is this helps.
Nige.
Starting SVCD2DVD: v1.5.1424.30178
Begin time: 23:27:45
******** Ripping BIN images to get mpegs (VCDGear)
Analysing File: E:\Movies\MPEG\Scarecrow_new.mpg
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:01.3c]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:07.0d]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'previous_I_offset': [00:01.3c]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:01.3b]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:07.0c]
++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
Analysing File: E:\Movies\MPEG\tcf_cfa_01_new.mpg
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:01.1a]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'previous_I_offset': [00:01.1a]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:09.4a]
Analysing File: E:\Movies\MPEG\tcf_cfb_01_new.mpg
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [01:39.2b]
Analysing File: E:\Movies\MPEG\Wrong.Turn.DVD.SCREENER.SVCD_OBUS(1 of2).mpg
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:01.1b]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0a.01]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:01.1f]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:01.1d]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0a.04]
Analysing File: E:\Movies\MPEG\Wrong.Turn.DVD.SCREENER.SVCD_OBUS(2 of2).mpg
-->Processing 5 mpeg files.
############### New MPEG File ###############
Type: SVCD
Horizontal Res: 480
Standard: PAL
Audio SampleRate: 44100
******** Demultipexing original mpg file
(Total size: 1173MB, Duration: 00:14:29, Rate(MB/Min): 80.97)
******** Resampling audio from 44.1 KHz to 48 KHz
(Total size: 138MB, Duration: 00:05:32, Rate(MB/Min): 24.93)
******** Multipexing elementry streams
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File E:\Movies\MPEG\Scarecrow_new_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File E:\Movies\MPEG\Scarecrow_new_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (E:\Movies\MPEG\Scarecrow_new_DVD.mpv)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 480
INFO: [mplex] Frame height : 576
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 25.000 frames/sec
INFO: [mplex] Bit rate : 1652000 bits/sec
INFO: [mplex] Vbv buffer size : 114688 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (E:\Movies\MPEG\Scarecrow_new_DVD.mpa)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 1 original
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 1910800
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 13019
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
**ERROR: [mplex] Failed write: E:\Movies\MPEG\Scarecrow_new_DVD.mpg
(Total size: 682MB, Duration: 00:07:04, Rate(MB/Min): 96.47)
Analysing File: E:\Movies\MPEG\Scarecrow_new_DVD.mpg
++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
Type: SVCD
Horizontal Res: 480
Standard: PAL
(Total size: 906MB, Duration: 00:10:24, Rate(MB/Min): 87.08)
(Total size: 73MB, Duration: 00:01:49, Rate(MB/Min): 39.88)
INFO: [mplex] File E:\Movies\MPEG\tcf_cfa_01_new_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File E:\Movies\MPEG\tcf_cfa_01_new_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Scanning for header info: Video stream e0 (E:\Movies\MPEG\tcf_cfa_01_new_DVD.mpv)
INFO: [mplex] Bit rate : 2520000 bits/sec
INFO: [mplex] Scanning for header info: Audio stream c0 (E:\Movies\MPEG\tcf_cfa_01_new_DVD.mpa)
INFO: [mplex] rough-guess multiplexed stream data rate : 2791848
**ERROR: [mplex] Failed write: E:\Movies\MPEG\tcf_cfa_01_new_DVD.mpg
(Total size: 263MB, Duration: 00:02:34, Rate(MB/Min): 101.82)
Analysing File: E:\Movies\MPEG\tcf_cfa_01_new_DVD.mpg
Type: SVCD
Horizontal Res: 480
Standard: PAL
(Total size: 927MB, Duration: 00:10:32, Rate(MB/Min): 87.99)
(Total size: 73MB, Duration: 00:01:51, Rate(MB/Min): 39.12)
INFO: [mplex] File E:\Movies\MPEG\tcf_cfb_01_new_DVD.mpv looks like an MPEG Video stream.
**ERROR: [mplex] Unable to read from E:\Movies\MPEG\tcf_cfb_01_new_DVD.mpa.
System.IO.FileNotFoundException: Could not find file "E:\Movies\MPEG\tcf_cfb_01_new_DVD.mpg".
File name: "E:\Movies\MPEG\tcf_cfb_01_new_DVD.mpg"
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileInfo.get_Length()
at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
The first error
Are you running out of disk space?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Unable To Register BOTH SVCD2DVD & VOB2MPG Pro
By noyou in forum SVCD2DVD & VOB2MPGReplies: 19Last Post: 21st Sep 2014, 18:40 -
Unable to create DVD using Pinnacle Studio Ultimate 14
By avz10 in forum Newbie / General discussionsReplies: 0Last Post: 1st Mar 2010, 09:06 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Unable to create chapters while converting from AVI to DVD using DVDAuthor.
By sumit_pankaj in forum Authoring (DVD)Replies: 7Last Post: 11th Jun 2009, 01:40 -
SVCD2DVD 2.5.2725 Wont create dvd
By Stuart-ASI in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 21st Jun 2007, 18:54
