Hi, guys!
I've tested Main Concept 1.4.1 capture feature and I think the quality is very good. It can capture directly to MPEG 1/2 or AVI with codecs. The only problem is it doesn't save capture format in settings. If you exit and open it again it will capture to uncompressed AVI.
Does anybody know how to fix it?
Thanks in advance.
