I tried to flash this drive from v1.38.to v1.64 with the program from
aopen's website did everthing it said I must it failed to update end of the
update it said check source file NG NG NG someone else had the same problem a while back but nobody answered his thread does anybody know now thanks![]()
I just did an upgrade of the firmware. Had no problems at all. Maybe you should try to flash with the 1.38 and see what happenes. If that is OK your writer will at least do something again.
Firmware update after regionhack?!
By little demon in forum DVD & Blu-ray PlayersReplies: 8Last Post: 27th Nov 2009, 23:50 -
Where to Get Firmware Update
By Teac23 in forum ComputerReplies: 1Last Post: 26th Apr 2009, 13:52 -
update firmware
By avextraxjp in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2008, 22:46 -
Firmware Update Question ##
By ofield1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Mar 2008, 06:56 -
DVR1112D firmware update?
By videobread in forum DVD & Blu-ray WritersReplies: 3Last Post: 15th Sep 2007, 20:02
