ok i am at the end of my rope..... i used IFOedit to created 3 videos that have 3 audio tracks and 2 subtitle tracks... but i always end up with the same two problems..
1) when i use power dvd to play them. the subs are all green
2) when using Dvd-lab to make menus and chapters for the three i start to compile it but it always fails and gives me error message saying that my files need be elemantary files...
has any one else had this problem
Well i just updated to the full version/complete of dvd-lab 1.3 so i'm going to try again, so i 'll have the resaults in 4 days as to which if the problem can be Fixed
this says you can put subtitles in.
https://www.videohelp.com/forum/viewtopic.php?t=179271&highlight=
and i going to test to see if it was the audio too.
Audio length
audio 1= 1.23
audio 2= 1.22
audio 3= 1.24
DVD Lab Pro Error b4 compiling
By _yoyo in forum Authoring (DVD)Replies: 1Last Post: 20th Apr 2008, 19:39 -
a problem with result DVD after compiling with DVD-Lab
By soroush in forum Authoring (DVD)Replies: 4Last Post: 11th Dec 2007, 15:58 -
Video Type Doesn't Match prob when compiling DVD Lab Pro project
By ulrichburke in forum Authoring (DVD)Replies: 6Last Post: 11th Dec 2007, 14:31 -
[ERR] GOP size is over the buffer limit - Compiling in DVD-lab PRO 2.30
By Wolverene in forum Authoring (DVD)Replies: 7Last Post: 31st Aug 2007, 23:55 -
DVD Lab Pro audio is out of sync after compiling
By GangstaRap in forum Authoring (DVD)Replies: 5Last Post: 8th May 2007, 05:46
, i'm exactly have the same problem with you,
