Hello, My IE 6.028 browser used to give me alittle click when I selected a hyperlink. Now it does no more. Can someone tell me where I can find this toggle?
WinXP Home
IE 6.028
yeah, go to the Control Panel select Sounds, Speech, and Audio Devices and select Change The Sound Scheme, a window should pop up displaying the properties. Under the Sounds tab scroll down (under Program events) to Windows explorer. under Windows Explore highlight Start Navigation and select a sound from the (under the section title Sounds) pull down menu just underneath it. The default sound is Windows Start, this the one that gives the click sound
hope that helps -
AWESOME! Thanks!
I knew it was an easy fix, just couldn't remember.
Thanks again
Tony
IE 8 - private browsing
By jyeh74 in forum ComputerReplies: 6Last Post: 4th Dec 2010, 07:34 -
Any Streaming experts browsing right now?
By Chala in forum Newbie / General discussionsReplies: 2Last Post: 13th Sep 2010, 19:44 -
Benq 1620 tray will not open? Just makes a click sound.
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 23rd Jul 2009, 01:12 -
Question about image-free browsing
By Brent212 in forum ComputerReplies: 6Last Post: 15th May 2008, 13:59 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 09:44
