Closed Thread
  1. does anyone know where the files are that remain on you computer after you uninstall Video fixer. i want to reinstall it. it was a trial.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    i kinda think the idea after a trial is to either buy it or not use it again ...
  3. no there is a way ive done it before but i forgot
    Jul 2003
    michigan
    I think you missed BJ_M point, it's probably easy to do, but it's basically stealing
  5. klik start, run, type regedit then open up the registry tree tosoftware in both current user and local machine. find the registry key for your software, right klik it and select delete. reboot and reinstall your trialware
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    good one -- except thats not it in this case .... please also read the site rules ...
