Hi,
I am trying to do a DVD backup of Dracula2000 using the mpeg2dec guide from Doom9's webpage. I have done a number of them in the recent past with the same method and been quite successful, not today though.
I re-installed my OS yesterday and thought I brought it back to the point where it was before but now when I run my AVS script all I get is this:
"Unrecognized Exception!"
"(G:\DVD_TO~1\MPEG2D~1\DRACULA.AVS, line2)"
I have re-installed AVISynth, redone my *.d2v project file, and some other things, and nothing. I am using the same basic working script I was using before, it is straight off of Doom9's webpage.
I have ran a small avs script, the "Version" one and I get what I am supposed to so I know AVISynth is working.
The last peice of info is that I ripped the DVD before I re-did my OS. Don't know if that has anything to do with it.
I am stuck, please help
Sorry for the long post
MDK
<font size=-1>[ This Message was edited by: MDK on 2001-10-12 12:03:48 ]</font>
Try running TMPGEnc with the VFAPI plug in, 1.2i or below will do fine..
TMPGEnc has superior quality to any other encoder anyway..
Good luck!
<hr>
Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
<hr> -
MDK, please post the complete avs. There is something wrong in line 2. Usually this is
mpeg2source("G:\full path\movie.d2v")
<font size=-1>[ This Message was edited by: Truman on 2001-10-13 19:46:07 ]</font> -
Hi,
Thanks for your responses. I eventually figured it out. It came down to the fact that although the VFAPI plugin was checked in DVD2AVI the latter could not locate the actually plug-in. Once I put both pieces of software on the same in drive and in thier own folder everything worked out fine. I guess I thought I had tried everything but I guess not.
Thank you again for your help and sorry for the lengthy delay in responding.
MDK
Unrecognized Format
By sergiozambrano in forum Authoring (DVD)Replies: 1Last Post: 9th May 2010, 21:38 -
unrecognized file?
By ninesixfour in forum ffmpegX general discussionReplies: 4Last Post: 10th Nov 2009, 13:10 -
MOV files are Unrecognized
By pherank in forum MacReplies: 2Last Post: 31st Oct 2009, 09:16 -
Unrecognized .avi file
By dvm8600 in forum ffmpegX general discussionReplies: 11Last Post: 5th Mar 2009, 17:06 -
unrecognized
By merkin1 in forum ffmpegX general discussionReplies: 1Last Post: 19th Sep 2007, 15:15
