I wanted to convert an Asf file to an Avi file using Virtualdub1.3c. I installed mpg4dxk and when I tried to open the Asf file in virtualdub1.3c an error pops up saying ASF: Data chunk not found. Any ideas?
The Asf file according to its properties>advanced tab says both it's video and audio codecs are WMV V8 so I can't use asftools according to doom9's guide.
The Asf is just under <1gb. I tried converting that in Tmpgenc to mpeg1 and it ended up being over >2.4gb so I tried compressing it to avi using divx 5.1.1 codec in virtualdub but that ended up being over >3.8gb. This conversion stuff is tricky.
Results 1 to 1 of 1
Help plz. :Capture AVI issue : Bad chunk in frame data: Invalid length
By chindoo in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2011, 19:51 -
Avi chunk viewer?- what is this?!
By vanjo in forum Software PlayingReplies: 21Last Post: 29th Oct 2010, 02:20 -
Optimal L1 Data Zone Start LBA: None found! (VTS_04)
By thief_ in forum Authoring (DVD)Replies: 0Last Post: 28th Nov 2007, 00:05 -
avi chunk viewer
By agent222 in forum Video ConversionReplies: 5Last Post: 15th Nov 2007, 10:03 -
Junk chunk size calculation
By maestro777 in forum ProgrammingReplies: 8Last Post: 1st Jul 2007, 05:16
