If I select an XVID avi with NTSC Film framerate and choose the VCD quick preset, the "Set 3:2" option is enabled by default.
But from all I've read, including Major's comments on set 3:2, this should be disabled for avi to VCD conversion.
Does ffmpegX just ignore the enabled 3:2 option for VCD conversion or should I disable it?
Results 1 to 1 of 1
ffmpeg - file for preset default not found
By velayudham in forum Video ConversionReplies: 19Last Post: 26th Jan 2012, 23:50 -
Quick AVI Creator 1 pass xvid preset?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 17th May 2010, 17:25 -
Default Preset when loading in videos?
By fredsanford in forum ffmpegX general discussionReplies: 2Last Post: 13th May 2010, 13:57 -
Subtitle Creator - Unable to set Default Subtitle Colors & Default Prof
By blue2 in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 23:47 -
Suggestion-Editable quick preset
By ilmz in forum ffmpegX general discussionReplies: 0Last Post: 22nd May 2007, 17:52
