I have a problem with Power DVD's screencapture feature.When trying to grab a still from widescreen movies,they end up looking not wide enough.Everything in the capture is tall and skinny.This does not happen when I get a grab from a full screen (4:3) movie.I usually open the bitmaps with Photoshop 7.Does anyone have an idea what I am doing wrong?
Yu mean they ARE wide enough, but they are too tall. which is a bit different. How are you viewing them, and for what purpose??
I hit that damn little camera button all day....nothing happens. Where do the screenshots go anyway? I had the video paused...should it be playing?
Their aspect ratio is squished so that a circle appears as a tall oval,faces are too narrow,etc.This happens with widescreen movies but not full screen ones.
Hech54,click on the little hammer/tack logo (configuration).Click on general,then advanced options,then capture.By default,PDVD copies the images to your clipboard.Just change that and specify a directory for it to dump all the bitmap images into.Yes,It will work also on pause.
Thanks....GOT IT.
Have to press that little camera twice sometimes...
Yep...I had to resize mine in Image Composer.Originally Posted by Otterpup
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 04:03 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 23:15 -
DL DVD on a Power Mac G4 Quicksilver?
By Vinnyqua in forum MacReplies: 3Last Post: 28th Feb 2008, 17:00 -
Does anybody have Power DVD v7.3?
By Sean_ve99 in forum Software PlayingReplies: 7Last Post: 11th Dec 2007, 01:12 -
question about Power DVD DX
By Bamahusker in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jul 2007, 18:35
