Hey, I created some VCDs, but they don't work on PSX 2. How can i fix the problem?
Make sure your discs work on a home dvd player and that you are making compliant vcd.
PS2 does not play VCD.
ps2 media player http://forums.afterdawn.com/thread_view.cfm/38260
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 04:11 -
890619 - convert TS to VCD compatible files.
By hamidi2 in forum VCDEasy GeneralReplies: 2Last Post: 9th Sep 2010, 17:21 -
What does HDTV compatible mean?
By optimus in forum DVB / IPTVReplies: 27Last Post: 6th Feb 2009, 03:19 -
Speedlink SL-6502 PSX2 Gamepad Converter button remaping?
By retroborg in forum Off topicReplies: 0Last Post: 28th Dec 2007, 19:29 -
Vista compatible?
By Slowburn in forum DVD RippingReplies: 2Last Post: 14th Jun 2007, 10:55
