  1. I need to know the apps and steps needed to accomplish the following
    strip AC3 track from a 3.11 divx file
    reencode the 3.11 to 5.1 (I 'll use dr divx)
    remix the AC3 track into the 5.1 divx
    thanks
  2. Member videocheez's Avatar
    Jan 2003
    Try this or a forum search. I have seen lots of threads on this subject.
    This is so much fun!
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Use Virtualdub and load your file, set audio>direct stream copy, set video>full processing mode, under video>compression>Divx 5.1>configure and choose your settings. Under file>save avi and give it a new name. Done.
    Good luck.
    Edit- If you must use DR Divx, load your file in Vdub, save wav will save the AC3 as is. Set Audio>no audio then save avi will save the avi w/o audio. Re-encode your video then load the new video into Vdub, audio>wav audio and select your original wav (actually AC3) audio, audio>direct stream copy, video>direct stream copy, save avi.
  4. sweet thanks,
    I'll give it a try
