Poll: !!Whats the best all in one DVD backup Software!!
Be advised that this is a public poll: other users can see the choice(s) you selected.
  1. So every one has there opinion about DVD backup software so what’s the best all in one maybe a vote on the Top five, Nero, DVD x Copy, Pinnacle and so the list goes on.
    You put your DVD in press the button it copies it to your HD, shrinks it to fit on one DVD+- R or RW then Burns it with not to many coasters and you have the option to play around with what ever part of the DVD you Burn just the film or the hole thing .
    Vote for your best software.
  2. I use CLONEDVD\ANYDVD although you have not listed it
    I also do it the dvd decryptor\dvd2one\recordnow max way.
  3. DvdShrink to rip and compress and Nero to burn.
    If dvd shrink dont work, happens sometimes with old disks then either
    dvdDecripter or dvdxcopy express.
    Not bothered by small problems...
    Spend a night alone with a mosquito
  4. What works for me sofar is Decrypter, Shrink, then CopyToDVD perfect Backups Or shrink CopyToDVD.
    Thanks to all sofar.
  5. The Big 3 ..... need i say more.
    Big 3 User.....
    PAL User.......
  6. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    I guess people have different needs as there are always different factors that determine which option people use. Some want movie only whereas some want more thna just movie only
    some just want a simple program where you put the original and blank DVD's in the tray and it spits out the backup as quick as possible with as little effort as possible. The other extreme is that some users completely reauthor/encode the DVD using longer manual methods and this is why you always get differences of opinion
    My methods ain't exactly one click but my main programs consist of the following below, if I ever backup a DVD that is. I can create a DVD exactly the way I want with a little user input and a little longer processing time. I don't need to backup 10 DVD's a day , so there's no real rush and there isn't a one-clicker that can come anywhere near the results anyway
    DVDDecrypter
    Ifoedit
    DVDStripper
    Menuedit
    DVDShrink (sometimes InstantCopy)
