Is there any software available (I sure there must be some) that allows me to adjust the output resolution/quality of my video beyond what my video card already allows? I am currently using an ATI AIW-7500 , but I would like to experiment with settings for TV output that are more specific than what the ATI provides.
I have seen at least one software (powerStrip I believe) that appeared to allow for this kind of settings. Settings I would like to experiment wth include refresh rates, and resolution (possibly 525 lines to try to match the TV? although I think this may be firmwared onto the card?).
For instance, I have read that 59.94 will make the best refresh rates when playing back video material and multiples of 23.976 will work best for film based material. Since the lowest common denominator for those two numbers (119.88) isnt supported directly, I would like a way to set this if possible.
Patrick
Results 1 to 1 of 1
Possible to output hdmi and optical output on the ps3??
By mrswla in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Feb 2009, 16:17 -
AutoMKV no output
By krisman in forum DVD RippingReplies: 16Last Post: 28th Oct 2008, 04:49 -
hdmi and av output
By gunukhan in forum DVD & Blu-ray PlayersReplies: 11Last Post: 1st Aug 2007, 13:04 -
how to get best output quality ?
By korsion in forum Authoring (DVD)Replies: 11Last Post: 25th Jul 2007, 21:41 -
Output to TV
By andyluong99 in forum Newbie / General discussionsReplies: 9Last Post: 18th Jun 2007, 20:05
