Hope everyone is doing well and that my fellow posters in the US didn't eat too much turkey yesterday.
I have converted tons of "home movies" from VHS to VCD/SVCD and recently to NTSC DVD compliant MPEG2s (for future burn once I get a DVD burner). Now...I have just gotten my hands on my first minidv camcorder and before I start shooting I have an initial question/concern.
I am currently working within the 4GB limits of Windows98 and will not be switching to XP anytime soon (read 6 months).
How is DV video stored on a minidv tape?
As 1 long continuous stream? (in that case how would I transfer enough to keep me under the 4GB limit?)
or
As separate files based on the length of the video segment? (I could shoot in small segements and transfer individually)
Thanks,
I'm pretty new to this area of computing, but I will share with you what I have learned. Maybe someone else can chime in to verify this...Originally Posted by babyboo
The answer is that it depends on how the scene(s) were shot. If you videotaped a one-hour scene, then it will be stored as one continuous shot. If you videotaped ten six-minute scenes, then that is how they are stored.
But it really doesn't matter how they are stored on the camcorder. Even if you have a one-hour long scene, you can always break it up with capture software into smaller files. For example, I believe that Scenalyzer will break up the download into multiple 2 GB or 4 GB files. I'm sure there are other capture programs that will do the same.
But once you get these scenes on your computer (in Type 1/2 AVI format), I am not sure what you would do with them (since you can't splice them together). Maybe someone else can help you with that part. -
As lots of 1s and 0s. It is a data stream, it isn't video at all.Originally Posted by babyboo
Although the contents of the tape are a datastream, it does have timestamps so you can easily find every different clip (the point when you pressed the record button). If you transfer about 15 minutes worth at a time you will keep below your FAT32 limit. Some transfer software can automatically split your files so you could capture a whole 1 hour tape and get 3 or 4 sequential files. You'll need to do a bit of research to find one that can do it.Originally Posted by babyboo
Transfering contents from one DVD to another?
By whatever911 in forum Authoring (DVD)Replies: 3Last Post: 23rd Feb 2012, 12:49 -
Transfering files to pc way too slow
By ccarlson62 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 23rd May 2009, 22:01 -
Help in transfering from HD Camcorder to PC
By jcikal in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jan 2009, 14:56 -
problem in transfering HDD to PC
By triassicpark1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Oct 2008, 12:18 -
4gb Limit on SDHC Card, FAT32
By AVCHD in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 05:24
