I made my first dvd backup yesterday with DVD X Copy. Worked great, put it into my dvd player and noticed the introduction screen saying something to the effect of "Backup: DVD X Copy Platinum".
Is there any way I can backup my dvds without having this introduction screen?
thanks,
Jared.
Jared, try to a search in the forum before you post. most of the info you need is already there. The following link will take you to a guide how to remove DVDXCOPY warnings, fbi warnings and all other warnings conatined in the dvd:
https://www.videohelp.com/forum/viewtopic.php?t=127933&start=0&postdays=0&postorder=asc&...0fbi%20warning
Hope this helps. -
Best and quickest way to get rid of that screen is to STOP USING DVD SHIT COPY.
- Gurm -
I have a better solution to remove the 321studios Backup screen, it will works all version of DVDxCopy even the Platinum, but sorry I cant share with you...dont want 321Studios to catchup and change it. All I can tell you is that there are 2 system files that are actually image files. If you find out those files ....replace it with any image file. It will take the Backup Screen out. All my backup DVD doesnt have it. Sorry that all I can share.
Getting "Fair Use" copy of last "Byrds of Paradise" episode
By Ronald Vaughan in forum Newbie / General discussionsReplies: 4Last Post: 14th Jul 2010, 21:09 -
Question about secret hidden "Back" button in Gui For DVD Author
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 15th Dec 2008, 03:17 -
Can I bypass "copy blocker" to copy from VHS to DVD
By jgloeckner in forum Newbie / General discussionsReplies: 10Last Post: 22nd Nov 2008, 23:40 -
Does DivXToDVD's "back-up" function copy or re-encode or both?
By moviebuff2 in forum Newbie / General discussionsReplies: 4Last Post: 18th Aug 2007, 17:00 -
Why to make "back-up's" of DVD's or TV programs?
By JimboS in forum Newbie / General discussionsReplies: 11Last Post: 11th Jun 2007, 05:39
