Closed Thread
    Jan 2003
    England, UK
    I have a problem with Instant Copy to author my dvds.
    I have a 7.45gb dvd ripped to my hard drive, when I use the normal procedure to encode it using Instant copy it says 4.50gb is too large to fit on a writeable media (customise disc) and it doesn't allow me to decrease the movie using the timeline.
    Here is a screenshot if you don't know what I mean: http://www.geocities.com/nrishiraj/instant_copy_screenshot.jpg
  2. Hi there
    Your link does not work!!!!
    Have you tried removing some audio from the dvd?
    sometimes when im using dvd shrink 3.0 i can not shrink the film down enough so i remove some of the audio streams & then dvd shrink can do its job - you should try the same to see if it works.
    can you normally cange the time line (with other movies you have done?)
    Please DON'T cross post.
    https://www.videohelp.com/forum/viewtopic.php?t=190634&highlight=
    watty: Copy the geocities image-link and paste in a new browser and it should work.
