I NEED HELP PLEASE I AM TRYING TO BACKUP UP THIS MOVIE AND EVERYTHING I TRY KEEPS GIVING ME THE SPECIAL EDITION COMMENTARY CAN ANY HELP ME WITH JUST GETTING THE MAIN MOVIE NO COMMENTARY THANX IN ADVANCE![]()
Results 1 to 12 of 12
What we have here is failure to communicate!!
1) turn off the caps
2) how are you trying to back it up?Regards,
Rob -
Do do not tell us what program you are using and you do not tell us how you are ripping the DVD. I have no clue on how to help you. Bet bet out of the dark usa ANYDVD from www.slysoft.com and dvdshrink and make a full DVD back up
first let me apoligize for the caps next dumb thing i forgot to do was supply info i have tried ripping with dvd shrink v1.03 don't laugh its work fine for everything till now if it ain't broke don't fix it. next was dvd decrypter and last was dvd fab and i recieved the same results with each one only the movie with commentary. in dvd shrink vts 01 appears to be the main movie with no commentary but i can't get it to ripp it keeps ripping vts 05 which appears to be the commentary version any help please thaanx
What we have here is failure to communicate!! -
Try the newest version of dvdshrink and use anydvd with it at www.slysoft.com also try clonedvd they give you a 30 day trial. Also if that does not work dvd2one. But if you use anydvd and shrink I bet it will work you do not have to rip the DVD to the hard drive with ANYDVD works right from the DVD-ROM drive.
do u mean i can backup straight from the dvd
i tried any dvd just caused my system to lock up so i uninstalled it
Make sure the selected video is actually the movie and not the commentary.I backed up finding nemo,and the commentary was selected instead of the movie as it was longer than the actual movie.Most programs will select the longest video,assuming it is the movie.
bmiller,ont.canada -
i tried selecting the smaller movie but it still gives me the movie with commentary no matter which one i select
Hollywood Boycott?
By 1337assassin in forum Off topicReplies: 42Last Post: 23rd Oct 2010, 09:42 -
Paragon Drive Backup 2010 Special Edition for free at GiveAwayOfTheDay.com
By freebird73717 in forum ComputerReplies: 19Last Post: 2nd Dec 2009, 15:18 -
special sub+idx
By akusoul in forum SubtitleReplies: 6Last Post: 6th Apr 2008, 05:00 -
xp black edition
By zookeeper525 in forum ComputerReplies: 5Last Post: 4th Jan 2008, 22:26 -
Remaking Special Edition: Inserting Deleted Scenes
By snipper_cr in forum EditingReplies: 0Last Post: 16th Dec 2007, 13:45
