  1. Im trying to rip my 1st dvd.
    Ive ripped the dvd with dvd decrypter and then use dvd2one to make the file smaller.
    What burning software is best I have nero but could do with help getting it right.
    Or if anyone knows a better way of ripping can they help In the end I would like them to be able to play on my dvd player.
    cheers
    mickmason247
    Oct 2003
    Central Texas, USA
    Open up Nero in DVD-Video mode. It will give u a bit of a wizard to look at. On the right, navigate to, then open the folder into which DVD2One put it's output files. Drag those files (NOT the folder they are in) over to the left INTO the VIDEO_TS folder that Nero provides. There should be 2 bups, 2 ifo's, and some vob files. Drag nothing else over. Burn.
