Hi All,
I would really appreciate if someone can tell a factory default
P-code for DVD951 made for US market.
Player's current settings: P-code is 33, and firmware version is 8.11.
As a result some controls on front panel, buttons on remote
control, bit rate UV meter, and S-video out do not work.
To find it out:
1. press 'system menu' on remote control;
2. press down button on remote until you reach 'left pointed hand' menu;
3. select 'left pointed hand' menu;
4. press down button on remote until you reach very last item;
5. press down button again and you will be able to see firmware version information (PHILIPS '98-'00 8.11 4234232 P33 4.13.30);
I need number after 'P' (p-code) that defines player's hardware configuration, or just tell me the whole line.
Thanks a lot.
atbb,
Just browsing these forums and came across your request. I can certainly tell you what my US market DVD951 tells me.
8.10 010622 P91 4.3.13
I noticed you have firmware 8.11, is that something you upgraded yourself or did yours come that way? The reason I ask is that I'm trying to see if a firmware upgrade will enable DVD-R playback. I can play DVD+R and DVD+RW fine but I'm trying to get DVD-R to work as well. Your reply is much appreciated.
Are OLED TVs really getting to the market ?
By bendixG15 in forum Newbie / General discussionsReplies: 15Last Post: 9th Jan 2012, 23:48 -
In the market for a new PC that would be great for editing...HELP!
By burrowsfan in forum Newbie / General discussionsReplies: 13Last Post: 11th Mar 2009, 00:07 -
HD is going to mass market soon
By hanugro in forum Off topicReplies: 0Last Post: 25th Feb 2008, 00:43 -
Playback of DVD Made on a Philips 3400
By Ensign in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Sep 2007, 09:35 -
philips 3400/37 - unable to duplicate dvdr made
By freebird1963 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Sep 2007, 13:56
