This is a error I get since update to build 1.5.1424.30178.
Analysing File: I:\wait to be burned\cut_cat\eso_tcha.mpg
++ WARN: packet length beyond buffer (pos = 18 + size = 2030 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
I can still make a disk but it will not play on my home DVD player it will play in Power DVD after I burn a DVD. When I try and play on hame unit I will have audio but no video. I am using Copytodvd ver 2.2.8.206 does any one know how to correct this?
Thank you for reading this
Computeman
Thats a warning not an error. You can ignore it.
Did dvds from svcd2dvd workin in your home player before? What is your player?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Yes it was working with no problems and plays other burnt dvds from past ok.
Computeman -
Did you do PAL or NTSC? And what format did the disc that play have?
Greatings,
Yf
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 10:50 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
