  1. Ok when i watch this dvd on my pc it is widescreen and then when i rip it ..it is fullscreen....and there are no other chapters to pick...is there a way i can rip it widescreen
    Oct 2003
    Central Texas, USA
    Some DVD's come with both versions on the same disc. If u rip with DVD Decrypter or DVD Shrink, you'll see 2 versions in the tree it shows u if u look close enough. I believe u can preview it with shrink after u rip the whole movie, but since I use decrypter, I pick one of the versions...rip for a minute or two...then view the result to see which one I picked. If it's the wrong one....I choose the other and rip. Don't forget to delete the semi ripped files before starting over.
    This may not be the professional way to do it, but it's quick and easy and works for me.
  3. If you play the movie in windvd it will tell you which title is the one you want.
