Hi,
I need to buy a video capture device that have this features :
- Capture at 30 fps 640x480 or higher resolution
- Video For Windows compatible
- Do overlay (to be able to loop the video Input to the Output)
- Win XP compatible
My software (it's a software for doing Video Assist in Film industry) support Pinnacle Miro DC 10+ and DC 30+ but this card are not suported on Win XP.
I need to find a video capture card that work in my software.
Any advice?
If anyone want to test my software you can find it here :
http://www.instashop.net/videoassitprosetup.zip
Video Assist consist of record what the 35mm Film camera see in the viewfinder and playback it for the director.
Your advice would be greatly appreciated !
Alex
Results 1 to 9 of 9
For high end cards, Alex, check out Winnov.
www.winnov.com
not in the same league as ATI and the other consumer players...
Winnov is Pro stuff.
Low end card with Audio and video inputs (RCA or SVideo) $250.00 US
Medium card with BNC connections $600.00 US
High end card with BNC connections $900.00 US
Advantage is audio and video are both captured with the same board thus guaranteed synchronization.--
Will -
I went to the winnov website and checked it out. Sounds to me this is more for capturing video for computer use since it can only do NTSC at 640x480 (not 720x480 nor 704x480 which are standard NTSC DVD resolutions). It says it can capture PAL at 704x576 as well as 768x576 (at least the specs seem to suggest this) but no DVD resolution for NTSC which seems odd.Originally Posted by willy_annand
Again this product seemed aimed at square pixel resolutions. Might be fine if you are going for DivX/Xvid but for MPEG-2 for DVD I doubt this is a good solution.
How much have you got to spend? Ati and Canopus cards are good, dependign on your budjet.
I don't have a budget limit.
I just need to be sure that my software will detect it.
I try a new Pinnacle Studio AV but it not work with my software. It don't detect it.
What is work is the Nvidia WDM video capture device but the VIVO in my G4 MX440 as no video overlay and i need video overlay.
Thank's!
Sorry for my english!
Alex -
Anyone want to test my software to see if their video capture device is compatible with my software.
It will help me a lot.
you can download it here (it just 2 mb) :
You can select (if it is compatible) your capture card in the Setting ->Select device-> Select capture Device window
Any help would be greatly appreciated !
ALex -
Well. I capture 720x480 @ 29.97 fps all the time with 0 frames dropped and total AV synch, on my P4c 2.6GHz 1GB RAM machine .Originally Posted by FulciLives
Then encode to DVD MPEG using either TMPGEnc or Edit Studio/MPEG XS.
The results I get seem clearer than the same source capped on my budies ATI ALL-IN-WONDERŽ 9600 PRO--
Will -
go to www.dazzlegeek.com Dazzle 2 is very good and ATI AIW is very good for remastering VHS I like my Dazzle 2 for Sattelite dish
I tend to like more and more all the external solutions like Datavideo DAC-100, Canopus ADVC-100 for DV, ADS Instant DVD 2, Pinnacle Moviemaker etc. (MPEG2) for the low price, excellent quality, portability, no need to open PC, firewire connectivity (or USB2). Can't beat ease of use, no drivers needed + ease of installation. Just look at the features of these boxes: http://store.yahoo.com/ambery/ looks pretty convincing and the price is just too good to be true. Definitely worth looking at.
Need some advice on a capture card for Xbox 360!
By smitty260 in forum Capturing and VCRReplies: 7Last Post: 29th Feb 2012, 22:23 -
video capture card advice
By MikeClark in forum Capturing and VCRReplies: 3Last Post: 10th Nov 2011, 22:10 -
PS3, HDMI Splitter, Video Capture Device or Card, Ambilight, ADVICE!
By NexusSIX1976 in forum Capturing and VCRReplies: 5Last Post: 16th Oct 2011, 20:38 -
Advice needed for an Xbox 360 capture card.
By Bonno in forum Capturing and VCRReplies: 2Last Post: 23rd Oct 2010, 16:15 -
need advice on choosing a capture card
By specane in forum Capturing and VCRReplies: 3Last Post: 18th Jun 2007, 10:28
