Hi All,
Just wondering if the sequence the optical drives can affect dvd/cd burning performance?
I've got mine like this:
*ALL DMA enabled / Autoplay disabled in WinXP*
IDE 1 Master: MSI dvd burner fw v2.30
IDE 1 Slave: LG Dvd-Rom
IDE2 Master: Plextor 52x cd burner
My hard drives are on the Serillal ATA interface.
The reason I ask is, which is more of a general hardware question, could my dvd-rom interfere with data flow to my dvd burner?
I've been using Ritek G04 -R's for my PS2 backups, using ISO read + write with dvd decryptor and the quality of the final discs seems to differ.
At the moment, i'm just trying, by process of elimination to improve the compatibility of all my dvd burns, so one day I can say 'I just use brand X for everything'
Any hardware experts care to chip with a different sequence for my optical drives?
Thank you,
B1.
You don't mention the MB or what processor or how much memory you are using, but obviously if you have SATA, it is fairly new. I don't really see any problem with your configuration. I can't see how they would interfere with each other. You could try putting the DVD-ROM as the second master because it is unlikely you would be running the CD burner at the same time as the DVD burner. It would help to fill out your computer profile in the future.
MKV2AVI best configuration
By katalogas in forum Video ConversionReplies: 0Last Post: 15th Jun 2010, 05:38 -
BDRebuilder Configuration Tool
By fritzi93 in forum Blu-ray RippingReplies: 3Last Post: 25th Mar 2010, 16:58 -
Need help configuring capture configuration
By tomarwater in forum Capturing and VCRReplies: 4Last Post: 9th Feb 2010, 06:11 -
minimum configuration for 1080p
By xenotox in forum Media Center PC / MediaCentersReplies: 26Last Post: 30th Nov 2009, 15:31 -
Network Configuration Question
By wwaag in forum ComputerReplies: 3Last Post: 31st Mar 2008, 21:56
